  • 4 weeks later...
  • 2 months later...
Silverbullet
Don't forget 20% off list price all motor parts.Genuine Chery Parts.In stock plus transmissions 5 speed & 4 speed.New motors 1100cc,800cc,650cc,Great prices.Yuma Az.If there is a problem we are Local.Plus we have made a deal with SKF bearing for trooper wheel bearing dual tapered roller bearing best material and quality control.Also a USA based company.Your money stays here.1 week for bearings to arrive plus snap rings will be available
Thanks Matt
    • By nrggaragebuilds
    • By Firewalker918
