Looking for a transmision
By rdc
By rdc
By 180gtr
Wheels
Tires
Engine
Transmission
Axles
Shocks
Control Arms
Throttle Body $90
Starter $150
Alternator $150
fuel pump $70
Map Sensor $50
Full set of Guages $150
Exhaust w cat, O2 SOLD
Ignition Coil - SOLD
Wiring harness and ecu SOLD
That would include....
Steering shaft, wheel
Ignition switch, key
Light bar frame, 2 lights
misc hardware, spindles
2 hubs, rotors
Engine mounts
Throttle pedal, cables
Shifter, cables
Clutch master, pedal
By Jody Deville
By Outlaw Redneck
Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando, I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
