Hello Jeff i could use some help.Kinarfi
silverbullet
Thank you for the question.
This is and interesting concept, and we do have a stage 3 controller that can read injector pulse width to modulate injection from our system. However using the nozzles and pump with no controller would require experimentation with relays and electrical which would be an R&D project we cannot currently support. It may be possible given relays to transform the injector pulse into a 12v signal to open a solenoid and energize the pump, but we cannot guarantee and results with out a snow performance control box on the system. Let us know if you have any further questions. Thank you for the question.
On Thu, Dec 8, 2016 at 3:05 PM, <[email protected]> wrote:
Hello
I am building a supercharger kit for small Chinese car motors 800 cc and 1100 cc.
We have a fuel management system that has a piggy back controller.The 800 cc 3 cylinder engine has 3 injectors stock so they added a piggy back system dis connected the 02 sensor and now adjust the fuel to the injectors.The company who makes them for us developed a controller with a separate maff sensor 5.bar for the 2 extra injectors.So we have 5 connectors for 5 injectors 2 for the super charger.So as boost goes up the maff sensor starts adding more fuel to the 2 extras injectors.The injector works on a pulse to open and close them.Is there a way to use this 1 injector wire to feed the water meth nozzle solenoid.I know it sounds crazy but if any body would know it would be you
Thanks Rich
    • By Kingfish
    • By Kingfish
      I have done a LiPo4 battery upgrade on my E1.  I have reprogrammed the charge profile to #386.  With the onboard BMS the controller cuts off all charge from the IC1200 when the battery reaches 100% to prevent overcharge.  When this happens the charger begins flashing the yellow light and displays the error code 013 which is telling me the battery is no longer accepting a charge input which is as it should be.  I hear a relay switching in and out every few seconds as the charger continues to try to reach the shutoff charge profile voltage.  My question is will it cause any harm to the IC1200 to stay in this state for hours or maybe even days if I don't get out to unplug it?  I used to leave the E1 plugged in all the time with the old Discover batteries.
    • By hetovi
      Hello everyone.
    • By Fordman1
