Hi, From Utah County, Utah, USA
Kinarfi
I was looking at the profiles of some and saw they were MEMBERS and I was still a NEWBIE, even if I did join earlier and my feelings were hurt, then I realized that it was my fault for not having posted enough times. So I thought I'd introduce myself. I live in Pleasant Grove, Utah, Disabled, it get easier say that if you say it a lot, & I hate it, from a plane crash. Always loved exploring and now I do it from a Trooper. I love to share my photos too, so I just keep adding to my collection at http://community.webshots.com/user/kinarfi. I spend a fair amount of time on the computer too. Married to a wonderful gal, Linda, and have 2 grown children and 3 grandkids, Don't you just love grand kids?
Jeff
Kinarfi, mate after seeing those photo's of your plane crash, you are indeed a very lucky man. You must of done something that only a very skilful pilot can do at the last minute to survive it. From what I've seen of Utah, like Az you've got lots of exploring areas to do in the T2. It will take longer than your plane but at least it will give you a different perspective.
Cheers Mike.
Jeff
Oh Jeff! I was just looking at your plane photos, you are a very skilled pilot and one very blessed man.
George and I are looking forward to going exploring with you and Linda next summer. By the way Grandkids are the best! George and I both agree that if we knew they were so much fun be would have tried to find a way to have them first.
Cinda
Cinda
My dad always told me to be a bachelor and to teach my kids the same. He forgot to tell me about grand kids, but then he hadn't met the ones I gave him yet either. :rolleyes:
Now that I think about it, I wonder if dad told my 2nd son the same story? No kids, yet, but we're hoping. (Some kids parents! ay!)
I wish I could take credit for surviving my crash. What saved me is that a rancher and his son saw me crash and got help coming and got me out of the plane in short order, I actually can't remember a thing from that day and was in a coma for the next 2 or 3 days. A nurse told me that with my injuries, I may have survived for about 30 minutes with out help. :(
Bless that rancher and his son.
Cinda
    • By doncaron
      Hello everyone!
      First of all I would like to thank you for the help with my timing problem, it was the chain. Now I’m looking for the part number for the wet clutch baring.  I’ve been looking for it but my side by side is a 2022 t-boss 550 and it’s not the same as a 2021. Can anyone help me please?
      thank you in advance again.
    • By Joe Toup
      Hey Folks
      There are not a lot of good sources out there for troubleshooting and diagnosing ECU problems with the Massimo Buck, Bennche Bighorn, Bennche Cowboy, & Cazador machines that use the Delphi MT05 ECU. They are all basically the same with different badging, so I thought I'd share some info that I found during some searches. I was trying to help someone diagnose and repair a hard starting issue.  The ignition coil was throwing a 0351 code.  I discovered how to read codes without an OBDII code reader.  The following procedures should help you check your fault codes and clear them if needed.
      Fault Code Troubleshooting for Delphi MT05 ECU on the Massimo Buck 400, Bennche Bighorn 400, Bennche Cowboy 400, and Cazador 400
      *NOTE: The MT05 ECU is not really OBD 2 compliant. It is much more similar to an OBDI system.  The MT05 ECU controls either 1 or 2 cylinder engines commonly found on Massimo, Bennche, and Cazador.
      Much of the ECU info was found here:
      https://netcult.ch/elmue/HUD ECU Hacker/Delphi MT05 Manual.pdf
      Delphi EFI System Design
      Delphi EFI employs 5 sensors to monitor engine performance.
      1. Crankshaft Position Sensor
      2. Coolant Temperature Sensor
      3. Oxygen Sensor
      4. Throttle Position Sensor
      5. Manifold Air Pressure/Manifold Air Temperature (MAP/MAT) Sensor
      Delphi EFI employs the following system components.
      1. MT05 Engine Control Unit (ECU)
      2. Fuel Pump
      3. Multec 3.5 Fuel Injector
      4. Idle Speed Control Valve (Idle Stepper Motor)
      5. Multec Ignition Coil
      6. Fuel Vapor Canister Purge Valve
      Using the Digital Dashboard to Decipher EFI Trouble Codes
      In addition to commercially available diagnostic scan tools (Big $$$), you can use the engine warning light of the Siemens dashboard to diagnose most of your EFI problems. The digital dashboard receives signals from the MT05 ECU, and the engine warning light will flash a diagnostic trouble code (DTC) if the ignition key is switched on/off for three cycles.
      When you turn on the ignition, the engine warning light will illuminate, which indicates the EFI system is operational. After the engine is started, the engine warning light will extinguish if the EFI system is working properly. However, if the engine warning light remains illuminated, it indicates the EFI system is not working properly, and there is a system component failure.
      Deciphering Diagnostic Trouble Codes
      To read the diagnostic trouble code (DTC), open and close the ignition key three times in rapid succession, as follows: open/close—open/close—open. At this point the engine warning light will flash a DTC which indicates the fault in the EFI system. Refer to the attached fault code table to identify the corresponding problem.
      The engine warning light will emit a sequence of flashing lights. If the light flashes 10 times, the translated number is 0. If the light flashes one time, the translated number is 1, et cetera.
      For example, if the MAP/MAT sensor is disconnected, or the connector is shorted to ground, the engine warning light will flash in the following manner (This is an example only).
      The engine warning light will flash 10 times: The first number of the DTC is 0
      After an interval of 1.2 seconds, the engine warning light will flash 1 time: The second number of the DTC is 1
      After an interval of 1.2 seconds, the engine warning light will flash 10 times: The third number of the DTC is 0
      After an interval of 1.2 seconds, the engine warning light will flash 7 times: The fourth number of the DTC is 7
      The resulting DTC is P0107.
      NOTE: For the system I was helping to troubleshoot, I suspected an ignition coil failure due to the code that was thrown.  When it was checked, it was flashing:  10, 3, 5, 1.  The 10 represents a 0.  So the actual code was 0351.  After finding the code, the coil wire was checked and discovered loose at the spark plug.  Once it was pushed fully on, the problem was fixed.  Most likely, this problem was created after the owner had pulled the spark plug to check the gap.  The ECU was rebooted using the procedures detailed below with no more codes being thrown.
      If there are other fault codes, the engine warning light will flash the next code in 3.2 seconds after finishing the first sequence.  After all existing fault codes are flashed, the engine warning light will repeat the fault codes in a loop sequence, until the ignition key is turned off.
      To clear fault codes you either need an OBDII Fault Code reader and a Delphi 6 pin connector adapter cable that you have to order from China and wait 8 weeks…OR....you can simply reboot the ECU using the instructions detailed below.
      Rebooting the ECU
      Perform the following steps to reboot the ECU.
      1. Turn off the ignition for 15 seconds.
      2. Turn the ignition on/off for 5 cycles. Make sure each cycle lasts about ½ second, verifying the start of the fuel pump for each cycle. If the fuel pump doesn't start during any cycle, begin the entire reboot procedure from the beginning.
      3. Turn off the ignition for 15 seconds.
      TPS (throttle position sensor) re-learn procedure after rebooting ECU.
      This should be done after replacing the TPS or the ECU....and it is advisable to check proper idle after rebooting an ECU too.   Source: ECU Hacker (Reworded process slightly to make it a more sensible flow in my mind):    1. Turn the idle screw one full turn clockwise before starting   2. Start the engine, and run at low idle until the engine warms.  Maybe a couple of mins.   3. Idle should be above 1500 rpm. If it isn’t, turn it up to 1700 then shut the engine off.  Do another reboot of ECU.   4. Restart the engine and let it stabilize at 1700 rpm.  Then turn the idle screen down to 1500 rpm and let it stabilize for a few seconds.  Once it stabilizes, set to the final recommended idle speed for your machine. The placard under (or behind) your seat should show idle speed, valve adjustment, spark gap, etc.  Typically the 390 cc engines in the "400" machines run at 1600 rpm idle.
        5. Shut it down. Wait 10-15 seconds before restarting.  The procedure is now complete.  Final Notes:
      I have included pictures of an OBDII connector and the Delphi 6 pin connector in case anyone wants to go buy stuff off ebay or local parts suppliers and build a connector to use for an OBDII reader. But...you can save money and simply do the same thing with code reading and resetting using the check engine light on your dash.  Some folks prefer to do it with code readers.
      Hope the information provided helps if anyone ever needs it but cannot find it in repair manuals. I discovered most of this in some motorcycle forums.  The source for the diagrams is here:
      Be advised: I am not a service technician.  I do not endorse any manufacturers. I do not get paid to help, nor do I want to.  This is just a hobby of mine.  I enjoy working on things and solving problems.  If you run into a weird problem that stumps you, give me a shout.  I may be able to give you some ideas...or not.  Just know, that troubleshooting thru emails can be challenging.  The more info you can provide, the better.  Otherwise, I will probably ask you a ton of questions.  The good news is, the Delphi system used on these machines is essentially an OBDI and it is very simplistic.  If you are methodical and patient, most of your "problems" can be figured out thru a process of elimination.  Always go for the simple things first before throwing money and sensors at a machine.
      Take care
      - JT
    • By MJG
      Hello,
      I found an 08 Renegade for sale and looking to purchase it.  I haven’t heard too much about these machines and any insight would be much appreciated.  Are they good machines?
    • By shaught66
      Hi. I am looking to purchase a plow kit to fit my 2022 Axis 500. I have looked online but only found one place to get one.  Does anyone have any place I could look? Thank you for your help.
