Engine Break in oil
Popular Now
By Big Dave11
2025 hisun ntx 550 intermittent clunking sound every 5 to 10 seconds coming from engine compartment when going gown hill in high gear two wheel drive with foot off the accelerator. Any suggestions would be helpful.
By lmarkie
Any thoughts?
By dogfood
Hello -
New here - and looking hard at a 2026 Mule Pro-FXT 1000. My wife insists we'll be going with the Platinum Ranch, because in her words, we already saved $ by not going with a Honda 1000-6. Ready to pull the trigger on this ... almost.
We were looking at the factory soft cab, but then realized this won't work with the standard hard top, as the soft cab has dual back windows to accommodate the 3/6 folding seats. However, we like the hard top. So recognizing there's a lot available in the aftermarket world, does anyone have suggestions relative to an aftermarket soft cab (sides, rear window, etc.) that will work with factory hard top, windshield and doors - and also allows for a (relatively) simple 3/6 seat conversion?
dogfood
By kmiller7351
Trying to get running a 550 Colman running but I think head gasket went bad. Do i just replace with new gasket, clean up and replace or is there more to it?
