Hello all,  my name is Derek, just picked up an Landmaster UTV with a blown Subaru 653cc engine in it.  Hence I am learning all I can toward success in an upcoming engine rebuild and or replacement. Not a lot of information out there it seems. Hope I can be of help at some point.
Hi Travis!  I think they ran it out of oil. Even though there is fresh oil in it now.  Has only 338 hours on it.   Mentioned a rod knock and-  that they kept using it. I bought it from a guy that works in construction.  Didn't get too hot at least.  It turned over, but makes clunk noises, when I get the side cover off,  the evidence will likely fall into my lap.  ;)   Paid $1500 for it, seemed like a deal for what we need it for.  Just hoping I can salvage what wasn't destroyed.  May swap in a Vanguard twin if I need to.  I have built many mower and ATV engines over the years, but never this setup.
Sounds like a good deal!
I would find out if there is a undersized rod, and specs for grinding the crankshaft, that *might* be cheaper than having to get a new rod and crankshaft, possibly.
  • 4 years later...
On 1/20/2019 at 3:29 PM, DJ530 said:
Hey Derek. I've read your great build on the engine. i know it has been a long time since your build but U R correct when U said there wasn't much info out here. i have a LM400 with a Honda 390. My problem is that it will not turn over, but all fuss's are good and battery is fully charged. I'm pretty sure there is a "kill" switch for the shift lever so it will not start in "drive" or "reverse"  but can't find it.  Just wondering if U came across this switch in your build..  Hope U R still active on this site.. Thanks
    • By OBL
    • By Bucky4444
      Has anyone found a decent replacement for the factory mirrors on a 2020 1100C?  My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years.  Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement.  .
    • By Eman85
    • By Jeff freeman
