07 Joyner sand viper engine & transmission swap
Popular Now
By rdc
By rdc
By 180gtr
Wheels
Tires
Engine
Transmission
Axles
Shocks
Control Arms
Throttle Body $90
Starter $150
Alternator $150
fuel pump $70
Map Sensor $50
Full set of Guages $150
Exhaust w cat, O2 SOLD
Ignition Coil - SOLD
Wiring harness and ecu SOLD
That would include....
Steering shaft, wheel
Ignition switch, key
Light bar frame, 2 lights
misc hardware, spindles
2 hubs, rotors
Engine mounts
Throttle pedal, cables
Shifter, cables
Clutch master, pedal
By CarlB
I have a 2022 Hisun 750 Sector which comes with a locked rear differential. Was wondering if it would be possible to install an unlocking differential. I see that there are some Hisun made machines that come with the unlocking rear diff, such as Cub Cadet Challenger, some of the Massimos, and probably others. My concern is whether these would be a direct bolt on, using the original axles, drive shaft, and of course matching gear ratio. I've tried to match up part numbers but it seems every brand has their own number system even for parts that I know are identical. If anyone has ever done this swap or has any information about the whether these unlocking rear diffs are comparable to the Sector, I'd appreciate your input.
By Xov
