I've done a lot of research on that alternative. All things considered it will def cost more to go that route whether you go with motorcycle engine/transmission or car engine/transmission. A big part of the swap to hurdle is providing power to the wheels and what not takes a lot of fabrication. Not to mention the cost of the engine/transmission itself. If you plan on going that route definitely plan on spending some money.
We are going to do a Honda K engine with auto in our Sand viper The stock engine just does not have enough giddyup. We can make extra parts if you are interested. Look at our wcf discusion under long travel on our 1100 sand viper. We will  sell our 1100 engine and trans.
Their is several topics about using the vw trans that is supposed to be the same .I would also call Joyner USA and see if they have one in stock. I will have a transmission and engine available for sale soon.
  • 5 months later...
I do have the 1100 engine in the bug and I plan to swap it out. I would swap your engine out for a Honda D motor for the amount of work you are going to put into your bug  give us a Call at 661 822 8111
  • Popular Now
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By CarlB
      I have a 2022 Hisun 750 Sector which comes with a locked rear differential. Was wondering if it would be possible to install an unlocking differential.  I see that there are some Hisun made machines that come with the unlocking rear diff, such as Cub Cadet Challenger, some of the Massimos, and probably others. My concern is whether these would be a direct bolt on, using the original axles, drive shaft, and of course matching gear ratio. I've tried to match up part numbers but it seems every brand has their own number system even for parts that I know are identical. If anyone has ever done this swap or has any information about the whether these unlocking rear diffs are comparable to the Sector, I'd appreciate your input.
    • By Xov
