Thanks a lot!
We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT. We are truly beginners and welcome any and all suggestions. Thank you, we appreciate your help!
My 2021 Coleman Outfitter 550 has a rear hitch receiver. It works OK for my towing of junk around the property BUT it is NOT welded directly to the frame of the SxS. Instead it fits into a sloppy tube and is pinned in there by a 5/8" hitch pin. This allows the receiver itself to wobble around to a small degree which can be annoying in some circumstances especially if towing and backing a trailer, it can droop or sway side to side by an inch or two at the ball. . I cannot figure out why they set up the hitch in this way, and am considering welding the tube directly to the frame as found in most hitch arrangements.
Has anyone else found this annoying and welded the tube up to the frame? If so, where there any down side to doing so? (Broken frame etc. ??)
