Hi Gerald & Travis & Dan
This is Casey from Leaf Asia.
Thanks for Travis, the Amazon link you post is my inventory in Amazon FBA warehouse.
Thanks, Dan for kind help on confirming.
Hi Gerald,
Please refer to the Amazon page for the shape of the shaft . Do you have manual for T2, if not, you can send email to me and I will send the manual to you for check.
My emal is [email protected].
Since the part is in US, Amazon currently can not send parts to Canada.  if you need, I will arrange shipping from China to you. Let's discuss in Email. Thanks
Best regards
Casey / Leaf Asia
  • 5 years later...
    • By nrggaragebuilds
    • By mrpro
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By dilger
      Transmission vent leaks oil out of it after using
