2003 Mule 3000 dies at takeoff
CLB
2003 Mule 3000 idles fine and runs fine once in motion, but sputters and tries to die at takeoff. It will idle fine when put in gear, but as soon as I press on the accelerator it will die if I don’t choke it. The choke doesn’t seem to be reacting as quickly as before either- it takes a few seconds at full choke for the rpms to increase. Once in motion, it runs fine again. I just rebuilt the carb, new air and fuel filters, and battery. Any suggestions?
https://www.amazon.com/Kawasaki-Service-Repair-Maintenance-2003-2008/dp/B00JDNDE4Y/ref=sr_1_1?keywords=kawasaki+mule+service+manual+3000&qid=1564512687&s=gateway&sr=8-1
 take a look at this,  CD manual for your machine, i have one just like it except for the 550, it's not very in depth, but it is enough to get by with and make repairs.
You might also check EBAY for a paper back service manual. They come in verrrrry handy.
No. Changed the spark plugs but that didn’t help. The only thing done before this started was rebuilding the carb. Found that the choke does work properly IF I manually push it down all the way on the lever on the carb, so it seems like it’s just not getting enough fuel at first. I’ve seen other posts where the plugs on the top needed to be removed to access adjustment screws. There are two. Anyone know which one does what before I start messing with them?
So it looks like the low idle is on the left and high idle on the right. Adjusted the high idle out about 5 turns and now it will take off without dying once it’s warmed up. Still a little sputter when it is first ridden but much better than it was. Now it runs backward for a sec when it is shut off but I’ll try and fine tune it later.
    • By Mark T
    • By wnc woods
      Is it possible to add a low gear to the Coleman ut400? If so please help. Ty
    • By AlphaSerenity
      Hello,
    • By Steve B
    • By Travis
      View File Kawasaki Mule 550,520,500 Complete service manual
      This is a complete service manual for the Kawasaki Mule 500,520 and 550 models.
      Topics  covered include Brakes, Steering, Electrical system, suspension and fuel system. As well as engine repair procedures and Transmission/Final Drive procedures.
      If you need more information about the engine this manual linked below is chock full of information.
      Thanks goes to @cliffyk for getting these files all  into one PDF format for uploading.
      Submitter Travis Submitted 04/18/2021 Category Kawasaki
