AXIS 500 WILL NOT START. HELP!
By BWF
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
I am at a loss, please help!
Brad
By Burk
By Kierobi
By Hunterman22
Can anyone please tell me or send a link as to how & where to hook up a code reader to my 2021 Hisun 500 Axis. I have a 6 pin to a 18 pin adaptor and the blue cord VAG KKL adaptor .Just not sure where or what to hook up to. Can I use your typical vehicle code reader or do I need to download something on a laptop or PC???
By Butch
