Any thoughts ?
I use  CASTROL ACTEVO  .Wet clutch approved  10w40. Have used it for years in all my ATVS ..Never fried a clutch yet. Buy it by the big jug at Wallyworld.  I did see a guy put STP in his Honda once..clutch began slipping in hours .
  • Thanks 1
Just changed my oil in my MSU 500..boy it was dirty..it's dusty ,very dusty here when it doesn't rain. Used Actevo 10w40 JASO M2  wet clutch oil..manual says 2 qts but it took 2 1/2 qts to get it where I feel comfortable..Some shops recommend 3 qts or more but I just can't see it..crank spinning in oil can't be. Good
  • 3 months later...
We use synthetic Shell Rotella T6 15w-40 in the Summer and synthetic Valvoline Ultra Powersport 4-stroke 10w-40 in the Winter here in West Michigan. Both are JASO MA/MA2 certified and have high levels of zinc that supports wet clutch designs. We've NEVER had any engine problems related to using this oil and it's our go-to when servicing customers' machines. Hope that helps... 😉
On 4/6/2025 at 11:32 AM, Prepper said:
Any thoughts ?
Dont know whats changed in clutch material or if it has at all but i have a 91 honda 200 fourtrax,the manual calls for 10w40 sae which is all thats ever been in it,i just recently,within a year changed the clutch pack,first time since bought new and actually the clutches still looked good but its a honda and i still only use 10w40
    • By AaronD1982
      New starter solenoid....check
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By Jamie 67
    • By AaronD1982
    • By Eman85
