You can post now and register later.
If you have an account, sign in now to post with your account.
I have a 2007 Joyner 1100 sand viper and before it even get's to where the thermostat opens up the oil pressure get's so low I have to shut it down. What could fix this ? I thought about adding an oil cooler with fan, thicker oil, or removing the thermostat. Any advice?
Thanks for your help
My Massimo 500 will not start. I’ve checked all the obvious things. It turns over just fine. fuel, spark, fuse box are all good. I can’t figure it out. Any ideas would be greatly appreciated. Thank you.
