1990 Kawasaki 2010 Mule Crankshaft Shim
Popular Now
By kmiller7351
What electrical connection are missing in battery comp? it seems I am missing plug in connections and I am not sure what and how it is supposed to look like. If I can get an image and guidance would be great.
By lmarkie
I swapped out the Subaru motor for a Predator 670cc. If I remove the heat shield around the muffler, The stock muffler sits in there just fine with 1" to spare.
Only problem is the exhaust exit is toward the back seat instead of out the back.
Do you all think that the stock exhaust would be okay (just as effective) if cut a hole and welded a pipe on the reversed (opposite) end? Of course, plug the old exit end. Other option I thought of was to roll a tube 180° with a 7" center line radius and finish extention of 12" or so.
Any thoughts?
By Stubbsmobile
Hey yall,
Helping a friend out. he purchased a 2020 massimo buck 400 utv. has about 100 hours on it. after starting the engine, shifter in low, it does fine. when shifted to high gear, most of the time it acts like its not in gear completely, and it pops out and grinds bad. when you can get it in high gear, it acts like something is binding and it wont hardley roll before it jumps out of gear and makes that grinding noise. almost like trying to dr4ive a standard transmission car and start off in 3rd or 4th gear.
I have been on this site for several hours now, and totally understand the overall feeling about massimo utv. I can only imagine trying to find transmission parts when other members cant even find a fuel filter, lol.
A new transmission is (part#47516) $1159.99 plus tax and freight.
anyone have any other ideas or suggestions on what is causing the noise in high gear and not wanting to move?
Thanks ,
Chris
By AlphaSerenity
Hello,
By bcorneliusen
Hi,
I have recently inherited a 2017 Mahindra mpact 1000 S Diesel flexhauler. The small silver-bezeled indicator gauge on the dash is no longer working since the wires were accidentally pulled from the back. I have managed to connect the correct wires for the seatbelt safety but most are still unplugged. Any pics or a wiring diagram for that gauge would be helpful.
