    • By Skeeter22
    • By Rmillerdesigns
      Hello. I have a 2016 Massimo MSU 500. I was putting on a lightbar and i screwed up and didn't disconnect the battery so when i was taking of the positive cable to put on the power from the lightbar it sparked and now the utv has no power. I turn the key over and all i hear is a chirp. No lights or anything. Everything that comes from the battery to the jumper box up by the battery shows voltage but anything coming out does not such as to the winch or anything like that
    • By a4x4nutt
      2021 uforce 800  turning radius is awful .
      I just bought it  added perfex lift
      And 1.5 wheel spacers
      The turning radius was bad before the lift .
      I looked for steering stops under the tie rod boots and steering knuckle for steering stops . Found nothing .
      Are the stops inside the steering rack ?  Is there a replaced steering rack with longer throw to curb this issue ?
      Any suggestions?
    • By dragon
      I need help I have a 2016 Kubota 1100 RTV my tilt steering wheel locked in the upper position after using the side release. The handle works but does not release the steering wheel to a lower position. If anyone knows and easy fix, please let me know any help is appreciated. Be Safe, Thanks!
