2013 Massimo MSU 500 no spark
Bluegill
Well that's not a real great way to diagnose a spark.  There is an inexpensive tester that plugs inline and has a light.  You should use one of those instead.  That way the plug stays in the engine and has a chance to operate in normal conditions with respect to electrical ground and compression.
Also, you can troubleshoot the coil with a simple multimeter.  It will be right upstream of the spark plug.  Read the primary side and the secondary side (spark plug side is the secondary).  You will have a resistance value on each side.  If either side reads open or infinite, the problem is a burned out coil.
Nate sir. I  relaced the coil with a new one so I  know it not that. I have checked for spark that way for many years. It may not be the best but it does work. I also replaced the ecu with a new one so i know the problem lies elsewhere.  Just trying to figure hete to start next.
  • 1 year later...
  • 2 months later...
  • 3 months later...
    • By Buddee
      Any help appreciated!
    • By great8redsfan
    • By htrotte
      #1   While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head  The two switches are literally 6 inches apart.  Does anyone know what this third switch is used for?  If i can figure out how I will post pictures.
      Author #2   Finally got the pictures took.  See the photo and tell me if you know what the switch on the right is.
      It looks to be factory and I know the girl who bought it new and she didn't install it.
      I can't find anything on it in any manual i have looked at.  Any help would be appreciated.
    • By joel b
      i purchased a brand new massimo tboss 410 and from day 1 it wont operate in reverse.  When i pop in reverse and give it gas it will die out.  when i pop in reverse sometimes in will die right away (before giving any gas) and 1 time out of 100 when i pop in reverse it will operate perfectly fine.   and yes, it operates perfectly dine in normal drive H and L.  any thoughts??   when i called the dealer i got it from they had no idea.
    • By todd93
      Hi, all! I. I'm new to the board, hoping someone could help me out! I have a 2020 Hisun Sector 550C that I bought new in 2021. Today, I took some stuff next door to my parents. When I went to leave, I turned on the key, heard the solenoid click, but no lights, no guage activity, no fuel pump, and no starter.
      The battery is good, I checked all the fuses, they are good. Not sure if the relays are good, or even what to look for there. Is it possible that it's maybe a wire?
      I'm really stumped on this one! Any help would be deeply appreciated! Attached is a pic of the fuse box layout.
      Todd
