For some reason (I don't know where), I got the impression that the yellow check engine light on my 2021 Coleman (Hisun) Outfitter 500 ALSO served as a low oil pressure indicator.  I was thumbing though the almost useless user's manual, and found nothing about any low oil pressure indicator.   It lights upon key on power up as normal.  After engine start, it remains on for about 3 to 5 seconds before going out, consistent with the engine building oil pressure.  At least that is what I am thinking.
Does anyone know for sure if this yellow check engine light also serves as a low oil pressure indicator???
Thanks.
After review of not the owner's manual but of the Hisun engine tech manual searching the text for "oil pressure" I found only one reference for testing oil pressure on this engine.
It says to loosen a bolt that is the oil passage bolt, start the engine and wait to see if oil drips out of the loose bolt.   Pretty high tech eh?😒
I wonder if this would be a place to connect a manual oil pressure line to a gauge?
I would assume that would be “a” place if not “the” place. My vector 500 does the same thing, but judging by the length of time it remains on, I sure hope it’s not taking that long to build pressure. Mine is one year old next week, just turned 70 hrs. So far, I honestly could not be more satisfied with it. It has a couple of annoying little bugs, but It hasn’t left me high and dry yet. I think come winter I’ll poke around and check valve clearances and general inspection, adjustments and change trans and dif fluids along with oil and filters before laying it up. After my initial anxiety about buying a sub par product, I am now really glad I bought it. I’ll probably buy another one but if I do I’ll get it from a dealer, not a big box, even if I have to travel a few hundred miles
Yes, I agree, I bought mine in January 2022 at a local Tractor Supply, and it has about 80 hours on it now. So far, so good. Been pretty reliable but I only use it for property maintenance so no wide open trail type abuse. Although I have some large hills here that require 4WD to navigate.  Got a KFI 60" plow for it this spring so it will take on those duties this winter.
I may try to install a manual oil pressure gauge this fall just to be sure pressure is built.   I just don't know if the ECM is fed by one of the sensors on the engine.  I guess I could get in there with a light and a mirror to see if there are any block mounted sensors that might be oil pressure related.
The only thing I could find in the tech manual is how to test for the required 9.2 lbs of oil pressure at 1,500 rpms.  All that procedure tells us is to watch for oil leaking from the loosened oil gallery bolt.  How to and where to hook up a pressure gauge is no where to be found.   The whole manual is as if written by 12 engineers with a severe language barrier between them all.
I have purchased the sending unit, low pressure gauge,T and fittings. To install the sending unit in the line on top of the oil cooler. Just haven't gotten around to it yet.
I blew the head gasket and just waiting on the mood to hit to fix that.
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By Burk
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
