What year is my RTV 900?
jkitsmiller
Let's presume the first character is missing from the VIN.  If so, then the year model charactert 6 would become the 10th character and indicate that it is a 2006 or 2036 model year (not realistic).
If we presume the last character is missing from the VIN, then the 1 to the right of the 6 would become the 10th character and indicate that it would be a 2001 or 2031 model year (not realistic).
The letter O or the number 0 is never used to indicate the model year.
So, lacking any further info, the letter A is the closest to any realistic model year character and that indicates that it might be a 2010 model year.
(770) 532-0038 is their phone number in GA.  I don't know if it is still active/current.  But it would be worth a call to see if they can help.
  • 1 year later...
  • 1 year later...
On 11/28/2019 at 9:58 PM, Dan B said:
This site will decode your number:
https://www.vindecoderz.com/EN/KUBOTA
However, the numbers you provided don't contain the full 17 character format.  Double check to see if there's another set of numbers on your machine.
Here is a free alternative of VIN decoder that I am using regularly: vinpit.com
Hope this helps in case you need one.
  • 2 months later...
  • 4 weeks later...
    • By TomW
      I had a problem 6-8 mo ago when the unit would not start . But you could see power on the dash. The starter solenoid was replaced and it has been fine until yesterday. When I started it up I noticed a high pitched noise coming from under the front. Like a alarmbuzz ..It seemed to drive fine so I went ahead and used it off and on for a hour or so . The noise would not go away . I parked it in the shed and lifted the hood . It seemed to be coming from the battery compartment ( where the new starter solenoid is) I jiggled the connections and the noise changed timbre and then the machine went dead. No power at all . No lights . When you cross the two poles on the starter solenoid ( previously last year it would start and run ) nothing. Checked the battery and it is fully charged . I checked the fuses inside the battery box and they all looked good  but I must be missing something. Anyone have a clue what I need to do next to R&R. The closest repair place is 2 hours away in Mississippi . Any help would be appreciated.
    • By REDfletching
    • By BOYD
      I have a 2004 KUBOTA RTV 900 DIESEL and I need to replace both front cv axels.I have been online looking at them and there seems to be a lot of different manufactures to choose from. My question is who makes a good aftermarket set of cv axels for this KUBOTA. I have read horror stories of people buying the  cheap Chinese brand only to find out they don't fit or they don't last very long and fail again. I hate to have to spend over $200 a shaft to get OEM from KUBOTA when I'm sure there is a company out there who probably makes it for them or makes comparable to OEM. Thanks for your help.
    • By Mark T
