I need to know if anybody is smarter than Chat GPT?
By jertex
I have two questions:
By OBL
By MilSurpYinzer
Anyone decent with electrical work that knows a good tutorial on how to make my running lights switch off all together but also turn back on when I need too? I'd assume that my lights are hard wired to the battery or the fuse panel.
Vehicle is a Kawasaki Krx 1000
I'm looking to ad IR driving lights for night vision and short of just putting black tape over the lights I feel this would be a more efficient option and it would be cooler.
By MilSurpYinzer
Tire chains for the winter
Bumpers because duh.
Thanks so much!
By Roadstar515
Does anyone know of a bypass switch or controller. They make one for Polaris which installs into the harness that makes the ECU think it’s hooked up in normal position allowing vehicle to operate normally as if you are wearing seatbelt.
