Hi! I have a situation where I cannot shift my Hisun 700 out of neutral. I have tried with the ignition (engine not running) and engine on. I removed the shift knob and it functions normally once removed from the linkage. It appears to be stuck at the lever where the other end of the linkage attaches to the transmission. I removed the cover and everything appears to look fine. Is this a sensor situation or mechanical? Any insight or help would be greatly appreciated.
thanks!
Griff
13 hours ago, Greg Kilgore said:
My bad completely misread the post. I have no clue what the issue could be. Only think I can suggest is try rocking forward and backward while trying to shift. But definitely looks like something is in a bind.
Yea, sounds like it is locked up. Getting someone to rock the UTV while you try to shift may help. Does the CVT belt rotate like it is in neutral or solid like in gear when you take the cover off?  Otherwise it doesn't sound too good for easy fix.
I had a similar problem recently. Turned out that a critter had stuffed a bunch of acorns and shells in the shifter box. I removed the box, turned it upside down and knocked all the debris out of it, and then it was fine.
    • By Sammy
    • By AlphaSerenity
      Hello,
    • By jertex
      I have two questions:
    • By OBL
