    • By Adrian Domingues
      Thanks for your help
    • By Eman85
    • By JohnnyB
      My Massimo 500 will not start. I’ve checked all the obvious things. It turns over just fine. fuel, spark, fuse box are all good. I can’t figure it out. Any ideas would be greatly appreciated. Thank you.
    • By AaronD1982
    • By AaronD1982
      Next problem with charging system to tackle, any help would be appreciated.
      New starter solenoid....check
      New Voltage Regulator...check.
      Dynamic test to Stator.....bang...pulling like 2 Volts AC
      Problem: Without pulling the part out and stranding the vehicle at the shop forever.... I am trying to find the correct stator or at least one that might not be exact for the Massimo Buck 400S, but fit and connect and do the job if that makes sense.... if anyone has any ideas, please shoot them my way.
