I have a Hisun Sector E1 UTV.  Worked pretty good for a while but then started to run into issue with gear grinding noise.  Will not engage in forward or reverse.  When put into forward or reverse and press pedal can hear a whiring noise as if something is supposed to be engaging but is not.  Occasionally it will grab in jolt forward momentarily but then ceases.  No error warnings or codes given.  Due to money restrictions, I really need to fix this myself.  Has anyone had this problem and what could it be that is needed.  Any help is appreciated.  Thank you!
  • Popular Now
    • By AaronD1982
      Next problem with charging system to tackle, any help would be appreciated.
      New starter solenoid....check
      New Voltage Regulator...check.
      Dynamic test to Stator.....bang...pulling like 2 Volts AC
      Problem: Without pulling the part out and stranding the vehicle at the shop forever.... I am trying to find the correct stator or at least one that might not be exact for the Massimo Buck 400S, but fit and connect and do the job if that makes sense.... if anyone has any ideas, please shoot them my way.
    • By Burk
      Can anyone please tell me or send a link as to how & where to hook up a code reader to my 2021 Hisun 500 Axis.  I have a 6 pin to a 18 pin  adaptor and the blue cord VAG KKL adaptor .Just not sure where or what to hook up to. Can I use your typical vehicle code reader or do I need to download something on a laptop or PC???
    • By Sidewinder
