Shift cable problem, 2017 Stampede 900, need advice
Popular Now
By OBL
By Eman85
By Jeff freeman
By Alex
What’s Included?
Why the RANGER XD 1500?
Entry Information
By Pop Bob
I had been driving for about 15 minutes, everything fine. All of a sudden the engine was surging, losing power, would run with 1/2 throttle or greater and was backfiring badly. Luckily I was close to home and got it back. The tipoff to me was that I thought I was hearing intake noise. Sure enough, the rubber boot which connects the air cleaner and intake piping to the throttle body came loose. Obviously the computer was confused. It turned out to be an easy fix, but this is now added to my inspection list. Just thought this might help someone else.
