  • 6 months later...
  • 7 months later...
There seems to be two levels of 'limp mode', when the  computer's 'on board diagnostics' (OBD) reads that one or more sensors are out of a predetermined range it typically will not let you operate the unit at full power but still allows you to get home instead of leaving you stranded.
That said, I have had an unresolved intermittent problem that has caused me to go into a limp mode like I just described (and seems to be hour problem too Vic), AND I have had a more serious limp mode that won't let the engine go much off of an idle.
Hope that helps, if I get my issue(s) figured out I will be sure to reply with the solution mine needed seeing as there's almost no info for these machines anywhere online!
  • 1 year later...
I have a 2017 Stampede that I purchased from a relative, it ran fine for about a month, then on the way to a neighbors place, less than a mile away, it went into a limp mode and will go over 3 to 5 miles an hour and slower on an incline. The engine symbol in the middle of the dash is flashing when I turn it on, and continues to flash as I drive it. It seems to have some power when I 1st start it, then losses power quickly as it heat ups. I am wondering if there is a high temp condition that is causing it to go into limp mode? Hs anyone else had this problem and what can I check next? I did check the radiator and overflow tank and both seem fine. There is very little information I can find on this UTV?
Lee
  • 8 months later...
    • By Nick Varnes
    • By Firewalker918
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By Sidewinder
    • By fikey
      I am about 6 months in to owning my 520. It is used mainly to run back and forth to our barn and shop. Occasionally, I run it up and down a few fairly steep hills on the property. One day, as I was going up one of the hills, the motor started sputtering and a tremendous amount of smoke was coming out of the exhaust. I was near the top and it made it (sputtering) up. Once back on the flat, I made it home. I loaded it on the trailer and took it back to the dealer. They said they checked everything out and found no issues. Over the next month or so, I only had occasion to go up hills once or twice with no issue. Then one day, again as I was going up a hill, the engine sputtered, giant plume of white smoke and then the engine died. 30 seconds later, started up and made it to the top. Repeated the route (down and up) and the same thing happened again. Called the dealer and their head of service said he would come out and wanted to see it first hand. He came out a few days later and repeated the route several time and it never happened with him in it. I had videoed the whole thing on one of the times it happened to me, but since it happens intermittently, could not produce it when he was here. I told him that I had checked the temperature, the oil level and the antifreeze level after each occurrence and they were normal. I asked him to call Kubota and ask what the possibilities were and that I am not fond of it dying on the hill and blowing the smoke and I didn't want to wait until something catastrophic happened to figure it out. When I followed up, they had no answers (which doesn't exactly please me). Any ideas? The attached photo was the start of the smoking. Didn't know how to upload the video of the whole thing, but it fogged the whole area.
