Massimo 500 will only crank when I jump solenoid with screwdriver cranks right up and runs great. But won’t start with key doesn’t do anything when I turn the key. Only thing it does is power everything as in dash and fuel pump then have to jump solenoid to crank up and drive.
My T-boss 410 does the same thing, but intermittently. Mine is probably a loose wire at the starter. Or the starter relay. I haven't checked mine yet, but let me know if I have helped!
  • Thanks 1
Yeah I checked all that. Can’t be loose because it fires right up when jumping the solenoid. Gonna mess with it more today after work. Will let you know if I find anything
I was thinking that when I had a buddy turn over the key and my power probe hooked to my solenoid its taking power away... so I don’t know if the points are bad in the ignition switch or my solenoid is bad? I have a solenoid on order I’ll change that if that don’t fix it then I’ll order a ignition switch.
No. I changed the ignition and solenoid with starter relay. Still nothing ended up going to auto parts store and buying a push button ran it straight to the solenoid so all I have to do is turn key on for fuel pump and all electrical stuff then push button and fires right up. Easy to do and now I don’t have a headache. Got tired of throwing money at it.
Does that mean it was most likely the starter switch? Kinda sounds like you narrowed it down to that, given that everything else functioned properly after you installed the new starter button.
It could be or it’s something in that stupid fuse box design where one of the relays are bad that you can’t replace you have to buy the whole box for $100 could be one of the  relays not allowing the ignition to work properly. So that’s why I just ended up putting the button on it. Still have to have the key to start so it will do for me.
On your solenoid you have a positive and negative run wire from each to a two prong push button once you do that and aslong as you don’t have a bad battery a your solenoid is good it will fire right up I attached a picture of a drawing that explains.
Thanks much! Mine is intermittent, but if I can't track down the issue, I just may install your fix.
Is the ignition switch only available through the dealership? If it's a poor design, I would prefer to go with an aftermarket switch. I don't know how to cross reference the switch, or I would go that route.
Initially, I was impressed by the detail that went into the manufacturing of the Massimo. But I may be premature about that, if in fact they have used cheap parts. Assuming that my model is different than yours, where is your ignition switch located?
  • 1 year later...
I have the exact same problem with a 2018 Odes Dominator 1000 cc. I still haven't found the cause of the problem. I "fixed" it by running a wire from the solenoid "I" terminal (the small terminal that is NOT connected to the ignition switch) to the frame. It now always starts instantly without waiting for the pump to do its thing first. The problem is solved but I still want to know what's causing it, if someone knows.
  • 1 year later...
Yes. It took a long time to get there. I tried to fix it by changing many parts that did not need to be changed: starter solenoid, battery, ignition switch, ignition button, starter.
I read somewhere that a bad ground could cause many such problems. I looked until I found the loose ground. It was staring at me the whole time near the center of the passenger side of the engine.
I bypassed my ignition switch and went to the solenoid connector. I ran a wire from my positive side of my battery to the push button switch, and from the other side of switch to the red/yellow wire of solenoid. I took the green wire from solenoid to frame ground.
But I will check for a loss ground on the side of engine.
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a  Dealer provided CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer sold CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By Tim n Deb
    • By Chile
      2018 Massimo MSU 700 EFI. I realize that this engine is essential the same as in all of the HISUN based Yamaha clones out there. I am in the process of performing a top end diagnosis/rebuild. I have an AMAZON top end rebuild kit on order in anticipation of this activity.
      Question 1:  When exploring the myriad of top end rebuild kits on the market for these units there are some cylinder assemblies that have "686 cm3" badging next to the cam cain tensioner boss. Others compatible with the unit do not have this badging. The existing cylinder assy does not have the 686 badging. I am assuming that this simply verifies that the cylinder assy is for a 686 cm3 engine which of course the stock 700 series HISUN engines are. Am I missing something here or is this just a manufacturer artifact? With or without the badging the application listings all indicate compatibility with the MSU 700 series engines.
      Question 2:  I have reviewed at minimum a dozen videos associated with this rebuild. To date I have not found one that deals with piston/cylinder clearance and/or ring gap verification. The advertised specifications for these various "top end rebuild kits" all indicate: Cylnider bore = 102mm and piston diameter=101.5mm. The math yields a .5mm (as in 1/2 mm) difference. That seems to be a very large piston/cylinder clearance.  I realize I am referencing advertised specs rather than emperically measured values but the numbers have gotten my attention.  I have referenced the FSM and found it to be somewhat confusing in this regard. Hopefully the experts on this forum can enlighten me as to where my observations are faulty here.
      Any and all assistance is greatly appreciated .
      Thank you all in advance,
      Chile
      Has anyone installed the power dump on a Kioti K9? If so, does it eliminate the safety lock? Does it work well?
      Thanks for your input
