I couldn't find anything on google or other websites....
 Pretty sure the camshaft will have a automatic compression relief on it that relieves compression out of the cylinder via one of the valves during start up, so usually when cranking the engine with a compression tester the reading won't be the Exact compression of a engine running at 2500 RPM, But, it seems to be  a baseline for all  small engines whether it be lawnmowers or 4 wheelers,  seems as though 85 to 90 PSI is the minimum to start a 4 stroke engine.
  • Popular Now
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By RBonds007
    • By RBonds007
      Looking for an online parts store.  Just need basic maintenance parts tune ups and such.  Any suggestions?
    • By Eman85
    • By CarlB
      I have a 2022 Hisun 750 Sector which comes with a locked rear differential. Was wondering if it would be possible to install an unlocking differential.  I see that there are some Hisun made machines that come with the unlocking rear diff, such as Cub Cadet Challenger, some of the Massimos, and probably others. My concern is whether these would be a direct bolt on, using the original axles, drive shaft, and of course matching gear ratio. I've tried to match up part numbers but it seems every brand has their own number system even for parts that I know are identical. If anyone has ever done this swap or has any information about the whether these unlocking rear diffs are comparable to the Sector, I'd appreciate your input.
