HELP - my wife and i just bought a 2013 joyner trooper 1100 and we rode for 2 evenings with no problems. Went to ride last night and all of a sudden it acted like something was catching up and it didn't want to move easily. Whatever it was must've broke and now it moves with no problem but is making a rubbing/grinding noise somewhere in the backend. Could it be wheel bearing, differential, or something in cv shaft. Any info or similar experiences is appreciated.
Short answer to your question about possible issues:  Yes.
Impossible to troubleshoot from a distance.  I would look at everything from the transmission output shaft to the wheel bearings.
Maybe put it up on jacks and listen to where the sound is coming from.
On 9/20/2020 at 6:03 AM, David Mcmillian said:
Has anyone found a replacement for Joyner Sand spider 650 cc outer cv axles ?
Welcome to the forum! For maximum exposure, and to observe forum courtesy, and tradition. You should open a new topic in the Joyner sub section.
Any luck with this problem yet?
  • Popular Now
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By brewski
    • By Jody Deville
