If it's an exact replacement, then it's pretty straightforward. Prep is everything though. New mounts, new rubber. New water pump, rebuild starter, alternator, depending on what you want.
The actual swap needs plenty of labeling, documentation. The whole thing will look different after a week or two, when you try to reassemble it.
  • 1 year later...
    • By Niko
      Need new pistons, rings, connecting rods and bearings for rebuild, dealer cannot get .5mm over pistons.  Looking for best aftermarket supplier.  Suggestions are appreciated.  Thank you
    • By AlphaSerenity
      Hello,
    • By Bucky4444
      Has anyone found a decent replacement for the factory mirrors on a 2020 1100C?  My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years.  Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement.  .
    • By mike28honda
    • By Nick Varnes
