07 trooper 1100 - appears to be detonating/falls on face at 3k rpms
  • Replies 33
  • Created
  • Last Reply
Top Posters In This Topic
    • By Xov
    • By monkthumper
    • By CaptainMorgan
      I have a Bobcat 2200 Diesel (built by Club Car) with a 2-weight Team Primary Clutch I want to rebuild, possibly replace. The clutch has an annoying rattling sound at idle and appears the rollers and weights are worn and loose. When I opened it up, everything looks clean and in great shape. It's just that all the moving rollers and weights seem to have way too much play in them, possibly causing the noise. I've searched for clearance and torque specifications with no luck at all. The UTV has less than 500 hours on it.  Any ideas?
    • By Flanman55
      I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly.  The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
      any help would be great.
      thanks
    • By Gerald Dillman
