QLINK Starting Problems
By donwan
I have a part that fell over to the exhaust and burned the harness up. I can't figure out what it is. Does anyone know what the start relay looks like? The part I can't figure out has 4 wires, a red power, a green and brown wire, a black and unsure what the 4th color was. Anyone have a clue?
By Buddee
Any help appreciated!
By JimS409
I picked up this Hisun 700cc for a good deal. no crank no start unit 1900 miles on it. Put a new battery and starter solenoid fired right up but sounded rough some kind of rattle/clunk noise. Does anyone know what this noise could be? Couldn't get a better video of it running as i don't want to risk doing more damage. Drained the oil it looks good no metal in it.
445374820_7315077208620291_6073155782020130975_n.mp4
By Anthony Vigil
Can anyone tell me how they grease the drivelines ? Can’t grease the u joints. Do you need to take the driveline off ?
And are they easy to take off?
By tim hughes
does any one else have a slipping belt on the hisun ...i put new wet clutch one way bearing new belt, cleaned primary and secondary and still get slight slippage
