    • By Skeeter22
    • By brewski
    • By Rmillerdesigns
    • By a4x4nutt
      2021 uforce 800  turning radius is awful .
      I just bought it  added perfex lift
      And 1.5 wheel spacers
      The turning radius was bad before the lift .
      I looked for steering stops under the tie rod boots and steering knuckle for steering stops . Found nothing .
      Are the stops inside the steering rack ?  Is there a replaced steering rack with longer throw to curb this issue ?
      Any suggestions?
    • By dragon
      I need help I have a 2016 Kubota 1100 RTV my tilt steering wheel locked in the upper position after using the side release. The handle works but does not release the steering wheel to a lower position. If anyone knows and easy fix, please let me know any help is appreciated. Be Safe, Thanks!
