I have a 2017 challenger 550 that will not go into 4 wheel drive. I’ve checked fuses, all are good, when I turn the key to on, and press the 4x4 button I can hear the actuator running , the front tires in the dash indicator light up as though it is engaged, but no 4 wheel drive. When I activate the front diff lock I can also hear the actuator but it does not show the x in the front axle on the dash. Any suggestions would be appreciated!!
I needed to use the 4 wheel drive on my Challenger and it would not engage. I checked all the fuses and they are good. With the key in the on position and machine not running I can hear the actuator run when the switch is pressed, and the indicator on the dash lights up but it does not go into 4 wheel drive. The front diff lock actuator runs when it is pressed but the indicator x does not show up on the dash, any suggestions should be appreciated!
    • By amiracle40995
    • By SkyPilot56
    • By Karlibob
    • By Paul L
    • By Joe Breaux
