What is the best way to tie down a SXS to a trailer. I'm thinking of using a nylon lifting slings (chokers) around a frame member and ratchet straps tightened to an anchor eye on trailer. Trying not to over think it but want SXS to stay on the trailer. Another question is do I place a ATY in front of SXS or rear.
I use ratchet straps  on mine... leave in gear with park brake on.. place heaviest weight to front of trailer. Too much weight on rear of trailer will make it duck-walk at 60 mph .. very unsafe  And if you have a  top on yours, make sure it is well secured.. Some will fly off at 60-70 mph
  • Popular Now
    • By RBonds007
    • By Eman85
    • By J Cardwell
      2024 villian overheating shuts down to crawl mode. If I turn it off for 30 minutes power returns to normal.
    • By oakhill
      When I am moving forward on my Hisun 500, the motor accellerates up and down while I have my foot on the gas pedal.  It also is not idling very well.  Both symptons appeared at about the same time.  What should I look for?  Thanks.
    • By hetovi
      Hi everyone,
      I’m considering installing a soft cab enclosure on my vehicle and wanted to get some insights from experienced users.
      I’m particularly curious about which materials hold up best in different weather conditions and how to properly secure the enclosure to prevent leaks or wind noise.
      Are there specific brands or models you recommend for durability and ease of use?
      Also, how do you handle cleaning and maintenance without causing damage?
      Any tips, tricks, or common mistakes to avoid would be incredibly helpful.
