The other day i removed my battery to check the acid level in it. It was still full. as i was reinstalling the positive cable the nut on the terminal stripped out. This battery uses a threaded insert that you slide into the terminal  the bolts screws into,  I was able to tigthen it up, but it's the kind of deal where if you kept turning it would get loose then tight, loose then tight. So after an unsuccessful trip to the parts store, tractor supply and hardware store, no one had what i needed, so then i did the smart thing and contacted Yuasa. Gave them all the battery specs and i now have new hardware kit on the way to me for FREE. For now  i have a small pair of  vice grips holding it, in case the bolt were to come loose while driving until i get a new hardware kit in. I did find the kit later on Summit racing, for $6. but hey, this is Free.
I have had good luck with CHROME Battery  products .. I ve bought 5-6 over the years for various machines. They have 24 month warranty which is twice what most have.. I had one fail at 18 months , called them, and had a new one in 3 days, FREE...Great service Dept.     CLEARLY no affiliation with Massimo!  HAHA
LOL
I will have to look into them,  this is the first time i used the OEM battery for the MULE in years. usually the O'reilly super start, get about 4 years out of a $30 battery.
 I got this one for 90 from the dealer... he came down from 130 for me. But it's done good.
    • By Sidewinder
    • By Stan M
      I have a 2026 Massimo 760L and also the Massimo snowblower attachment and would like to do a permanent install on the control cable and switch. Does anyone have a recommendation regarding the routing of the cable and mounting of the control switch?
    • By Terry B
      We purchased this UTV less than 60 days ago and now I am having issues with drained battery. Used UTV for about an hour then stopped and when I went to start back up my battery was to low to start it. Jumped it and it started right up and ran fine back home. Tested charging and it’s not charging while running. Can it be anything other than the stater??? Can I look for something that I can fix Quik or does it have to go to the authorized service center to stay under warranty? It will take some time to get it in and out of service
    • By kmiller7351
      What electrical connection are missing in battery comp? it seems I am missing plug in connections and I am not sure what and how it is supposed to look like. If I can get an image and guidance would be great.
