Ok I did finally manage to get some sound deadening installed in my 750. The product I used is a 200-mil peel-and-stick asphaltic/closed cell foam composite from Siless (available on Amazon). I installed it on the panel directly behind your hips (between the seat base and seat back) on the engine side; on the panel behind your legs between the floor and seat base inside the cab; and on the three access panel covers under the seat. I didn’t really feel like disassembling the cab to install the material on the engine side of the panel behind your legs, and I will likely make an aluminum cover panel over it in the cab to protect it from getting damaged, but it worked fine installing on the inside.
I have not had a chance to check dB levels yet, but I would say overall the cab levels have been reduced again by a similar reduction realized with the silencer. So I’m pleased with the results and the UTV is much more pleasant to drive.
  • 2 years later...
4 hours ago, H Loc said:
I am having same issues when idling as well..  I don't want to push pass 3000rpms or 15mph  bc its so loud  is that just the way it is?
Yep.  Add a second muffler and make sure the exit pipe aims down toward the ground. And insulation will help, too.
    • By OBL
    • By KMP
      We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT.  We are truly beginners and welcome any and all suggestions.  Thank you, we appreciate your help!
    • By kmiller7351
      Trying to get running a 550 Colman running but I think head gasket went bad. Do i just replace with new gasket, clean up and replace or is there more to it?
