2014 Mule 610 XC SE runability issues
By buckrub
By Nathon S.
I have a Bennche 700 EFI Bighorn. I’ve recently been unable to get it to start. After a little troubleshooting I realized my fuel pump was not pumping fuel. This weekend I emptied the gas and replaced it with new. I replaced the fuel pump, fuel filter and fuel injector. I also replaced the battery, spark plug and made sure all my fuses and relays were good. I have confirmed that the float on the fuel pump is not obstructed. The UTV is about 12 years old and has less than 100 hours on it. It has not run in over a year. Not sure whats going on?!? After doing a little reading I'm leaning towards it being an issue with the ECU or perhaps a faulty wire in the wiring harness. Anyone have any ideas on where to start looking or what I could be dealing with? Any help is appreciated, thanks in advance!
By donny
Hello I am new here but have had this machine for about 5 years. I am having issues with it surging and sometimes sounding like a small backfire thru the intake. When putting in low, high or reverse it will struggle then go full power then struggle. It will only do the small backfire thing while in neutral reving it many times. Once in awhile it will throw a check engine light.
Parts replaced/checked:
I have checked the valve lashing, timing and adjusted. Parts replaced are the coils, spark plugs, injectors, fuel lines, fuel pump, IAC sensor, TPS sensor, throttle cable, speed sensor, primary and secondary clutch and belt.
By SafeSledBryan
Hey guys! My name is Bryan and i am the owner and creator of Safe Sled. Not some crazy corporate backed recovery product, but just some guy with an idea.
4 years ago, I suffered 11 strokes, and am now 50% paralyzed on the left side of my body. I am unable to work a normal job anymore. I was working on the sled 2 years before this all unraveled. My wife told me to keep working on it since i was pissing her off staying home and doing nothing.
I still plan on improving and implementing different ideas as the product’s revenue continues to grow.
if the sled is appealing to you, please check out my website, safesledoffroad.com
Safe Sled Website
By Felderlostnspace
2016, Hisun 500 turns over great but Spark plug is firing when I turn the ignition key on. I’ve got good fuel pressure to the injector. Pulled plug out and it is wet with. gasoline. Air filter is clean. Turns over great just does not even try to pop or start.. I’ve checked off uses and they are good when I turn the key on I’m getting power to the injector.. I’m not hearing the injector pulsing, but may just be my hearing.. With the spark plug getting wet with gas I feel like the injector is pulsing and spraying. Any suggestions would be great. I don’t know the hours on the unit offhand, but it has 600 miles on it. Thank you for your comments and advanced.
