clutch problem
By didgeridoo
By OBL
By mehe
By lincolnsq175
I have a 2020 coleman ut400.
Any info is appreciated.
By esmarkey
Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in. It still acts like the belt is slipping but now I am thinking it is the clutch?
Can the clutch be rebuilt?
