The gauge cluster has power and works but the tach does not. All fuses are good so I don't know if it is the gauge problem or some other electrical problem. Anyone have any thoughts on what it might be? KBM
  • Popular Now
    • By Butch
    • By Rmillerdesigns
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By Timbo
    • By Sharon
