On 11/11/2023 at 7:43 AM, Joe Breaux said:
What the .....
that is the same reaction most people have when they arrive at a nudist campground by mistake. lol
10 hours ago, Joe Breaux said:
I would have thought the first reaction would be..." OH MY EYES! MY EYES!Cracking Up Lol GIF by Rodney Dangerfield
No, that is what people say if they enter our profile / about us.
@mehe I asked you not to post nude photos on this site. You are welcome to participate in our forums, but please keep the nudity to yourselves. Even your profile, which I just cleaned up. This is not the site for that.
On 12/6/2023 at 7:21 PM, cbass1116 said:
Lord have mercy, your husband is one lucky man.I would love to visit.
we have a few overnight camper spots for visitors and ATV trails.
  • 2 years later...
just an update....we did have a first ATV ralley and planning the 2nd for this summer. We are still looking for fun ideas.
On 1/19/2024 at 10:35 PM, that guy from Canada said:
My only concern is that technically your clothing to a point IS your safety gear when using ATV UTV
Seen many people burn a leg on hot ATV exhaust in shorts or regret short sleeves and no gloves if they wipe out.
Regardless please wear a helmet.
Cheers
and they were concerns of ours as well, so all of our riding events were "slow ride" events, and we tried to keep the riders to a limited speed. Most of our property is flat and the county let us use the paved bike trail which is flat as well. We did not require nudity although most were as naked as they could get.
  • Popular Now
    • By Cliffampranch
    • By gridlock
      After three years, my Sector completely died.  Something caused the hot wire under the seat from the charger to disintegrate, so the batteries weren't being charged.  The batteries weren't charging 100% anymore, so decided to convert to lithium.
      As most others have done, I went with 4-48v batteries in parallel, as I believe that will be plenty of amp-hours for my needs, but can always add more if needed.  I went with LiTime wired CAN batteries and mounted their digital gauge on the dash above the current one, which fit perfectly.  I didn't think the existing battery brackets worked well for the new batteries, so made my own out of aluminum L rails, which makes it much more secure (and saves a few more ounces :)).  Since I wired them in a 'balanced' configuration, I had to make all new cables from 0/1 gauge wire and 8mm posts.  I updated the DeltaQ charger to profile 233. Cleaned everything up (I must have vacuumed 20 pounds of dirt!), put it all together and... wham!
      So far, it definitely is better than with the original AGM batteries.  Sustains speed better going up hills, and seems to have plenty of reserve current.  The difference in weight with 4 LiPo vs 8 AGM batteries surely doesn't hurt!
      A few questions:
      In the 'any tips' thread, EVSupport mentioned reprogramming the Sevcon to reflect the new discharge curve of the lithium cells, but I didn't see any more info about that or how to do that.  Is there any more info about that?
      Have folks replaced the onboard 12v battery, and if so, with lithium?  I'm not sure why there is a 12v battery; why didn't they just step down the current of the 48v system to provide power to accessories?
      Is there a recommendation as far as charging with the lithium conversion?  As far as I understand, it is better to let lithium batteries discharge somewhat (but not completely) than keep them charging all the time.  What do you think?
    • By CKfrustration
      I have a Hisun Sector E1 UTV.  Worked pretty good for a while but then started to run into issue with gear grinding noise.  Will not engage in forward or reverse.  When put into forward or reverse and press pedal can hear a whiring noise as if something is supposed to be engaging but is not.  Occasionally it will grab in jolt forward momentarily but then ceases.  No error warnings or codes given.  Due to money restrictions, I really need to fix this myself.  Has anyone had this problem and what could it be that is needed.  Any help is appreciated.  Thank you!
