Got a new 2023 TBoss 560 with 40 miles on it now. Noticed after about and hour of plowing snow coolant started hissing out the overflow tube. Initially made a pop or blow kind of noise and then saw some steam and smelt coolant. Coolent level is in the middle between low and high (running or not). Coolant under radiator cap is full when cold, appears nice and green. Checked oil doesn’t look milky. The temp ranges from 160-180 F running for 15-20. Noticed the other day there was some more coolant that blew out the overflow tube. I called the dealer and they said the system could be purging air. Dealer is 2+ hours away so wanting to get more thoughts before considering to bring it in. Also noticing hot/burning rubber smell but I think this is from the belt breaking in? Also notice the coolant smell from the exhaust when in higher RPMs. No white smoke from the exhaust. Also another possible issue. I notice that there’s a little bounce when on pavement. You can also hear the CVT kind of make noise with this bounce in tandem. Is this normal?
Posted (edited)
You've checked the radiator cap is good? Run it parked for a bit with cap off and watch to see if coolant seems to be flowing. Sounds like cap could be bad and not providing seal under pressure.
Edited by Steve G.
left out word
    • By TapBoss
      So I’d been shopping for an enclosure for my ‘21 TBoss pretty much since I bought it. Then they came out with half doors and that’s the only one that I could find. Then the other day I ran across one on Amazon for half the price of anything else I’d seen. The link is below and I’m pretty impressed by how well it fits. There is one Velcro strap on the top of the door that doesn’t line up well with the roll cage, but I’ll work around it.
      https://a.co/d/09ACQ191
    • By Adrian Domingues
      Thanks for your help
    • By HighSon
      Locking gas door.
      Rear view mirror.
      Folding armrests.
      Folding rear seats.
    • By carbdoctor
      I have an 850. It’s been overheating. The electric fan is not kicking on. I see the temperature switch going into the radiator, but there’s no wire plugging in to it or none to be found in the area. i’m thinking I might’ve hooked on a branch and it ripped out the harness on that part. Does anybody have a picture or no where that plugs into on the harness? On the top of the firewall, I did notice some plugs that have nothing plugged into it. I was wondering if it’s a harness that goes from there down to the radiator that was pulled off
    • By Jamie 67
