Russian Tuff Truck Trooper Build
By rdc
By nrggaragebuilds
By Cliffampranch
By rdc
By 180gtr
Wheels
Tires
Engine
Transmission
Axles
Shocks
Control Arms
Throttle Body $90
Starter $150
Alternator $150
fuel pump $70
Map Sensor $50
Full set of Guages $150
Exhaust w cat, O2 SOLD
Ignition Coil - SOLD
Wiring harness and ecu SOLD
That would include....
Steering shaft, wheel
Ignition switch, key
Light bar frame, 2 lights
misc hardware, spindles
2 hubs, rotors
Engine mounts
Throttle pedal, cables
Shifter, cables
Clutch master, pedal
