If you translate the page using Google from Russian to English the article says in Russian but right at the top in English you will see Download in pdf here. Download it and then you can copy and paste it into a Russian to English on-line Translation website like this one here... http://webtranslation.paralink.com/ and read the article. Hint, don't copy and paste too much at one time. I've read the story and it's very interesting. It's called the Woodcutter and was built to go through dense wooded areas. I do like it, but realise it's not for every one. I also like the way they think outside the box. I might try and get one or two of them to post here just to get another point of view.
Cheers Mike.
  • 4 months later...
Just found this on Joyner Sport Russia's website. I can't copy & paste the Russian words to translate, but the pictures speak for themselves. Kind of reminds me of a Mad Max Buggy, but way cooler.
Of note rocmoc, check out the doors. That's thinking outside the box. What do you reckon. I like it.
http://www.joynersport.ru/news/2010/08/04/268/
Cheers Mike.
I think its pretty cool but those seats sure don't look very comfortable.
    • By nrggaragebuilds
    • By Cliffampranch
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
