Go to the top of the pinned and VOTE, NOW!!!!
By jertex
I have two questions:
By OBL
By Firewalker918
By jon pino
having trouble with a 2013 uxv500i. have replaced stator due to bad pulser coil. new unit does not work. manual value for pulser coil is 100ish ohm, measured value is 500 ohm. can anyone with one of these fuel injected later model units check their pulser coil with an ohm meter for me? left side of engine small connector next to 3 yellows. jon 605-545-7040
By jamesxevan
I’ve been eyeing a Hisun 500 soft cab enclosure upper doors setup for my UTV, but I’m really not sure if it’s a smart move. The idea of doors and some protection sounds appealing, but I worry they might just be a flimsy afterthought — weak zippers, thin plastic windows, maybe leaking or fogging when wet or cold. What good is “protection” if it doesn’t seal well? Also concerned about ventilation: with soft doors, does the cab get too muggy or stuffy?
Anyone here use soft-cab doors on a Hisun 500 — did they actually hold up for real riding conditions, or did you end up ditching them for hard doors (or no doors)?
