Well, just stopped by Silverbullet. Talked with Rick & Jose. Looked over 2011 trooper, Rick "made" :rolleyes: me test trooper!! Very impressed, new shocks, smooth tranny, acceleration was really good. New muffler on it from factory. Quite nice. Supposed to have differentials taken care of, & other problems fixed. Someone buy it, give it real test... Thanks Rick for test. :D
    • By KMP
      We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT.  We are truly beginners and welcome any and all suggestions.  Thank you, we appreciate your help!
    • By diamondjfarm
      Thanks.
    • By Greg Kilgore
      We all know summer is hot inside the cabs of our SXS. So I've rigged up a couple of fans to help cool down the cab.
      I didn't want to drill the fan's "support rails" into the ROPS (Roll Over Protection System), aka roll bars. So I used water clamps to hold them in place.
      I just need to replace the wires I ran with bigger gauge. Then finish the wiring to switches, relays, and battery. But the hardest part. The actual mounting of the fans is complete. Also just in case anyone plans on doing this. I may have to only use 1 fan in the middle instead on 2. Due the the draw on the battery.
      The fans are 12", 12V 80W. So I'm figured they were 6.7 amps apiece. Used the WAVe formula to get unknown values Watts=Amps*Volts then solve for unknown. I know the watts and volts from sticker on fan. So just used above formula to get amps. So a 7 amp fuse should be OK and a 10 amp fuse will be good.
      So pulling 14 amps from the battery all day may be too much for the charging system to keep up with. And I haven't even installed the radio yet. So I will have to test and let you know.
      See pics below.
