With the upcoming changes to Googles privacy policy, I will no longer be using any Google product with the exception of gmail (when I find a replacement, it will go also). A GREAT search engine is DuckDuckGo.com. They do not keep your info or track your computer usage. Give it a try.
rocmoc n AZ
When I first read this I thought what’s rocmoc got to hide and what sites is he looking at, but now I get it. Have a read here/ http://donttrack.us/ . That’s a worry and will give the duck a go.
BTW roc, howz it going? I thought of you today when my sons friend wanted to look at one of our old Trooper videos on YouTube and came across this vid that would make you shudder.
Mud, mud, glorious mud.
Cheers Mike.
Hi Mike, good to hear from you. Senting you a PM.
MUD, mud, I don't do no stinking MUD!
rocmoc n AZ
Tried to send you a PM but would not allow. Maybe your message box is full.
  • Popular Now
    • By AaronD1982
    • By Eman85
    • By Eman85
      Pulled fuel injector to see if I could clean it or if it's stuck open. Had a slide on clip that was really tough to get off. Don't see how the clip is supposed to lock into the plastic part that the injector slides into. Any videos or pics of injector replacement?
