I just picked up my Joyner Trooper T2 and am trying to get insurance on it. I went through my insurance agent and he set me up with what basically looks like an auto policy costing $800/yr!!!!! This seems way to steep. He was telling me that he could not find anyone who would even insure the thing.I know there are a lot of UTV's running around out there, I can't imagine it's that impossible to get them insured. What companies do other people use to insure your UTV, and what kind of yearly premiums are people paying?
Thanks for the help.
I agree with devildog.Below is the guy i went through and he got it for me with Foremost.Around 200-250 a year.
Fischer Specialty Insurance
Marc B. Fischer
[email protected]
7373 N Scottsdale Rd. Ste C-100
Scottsdale, AZ 85253
tel: 877.537.2555
fax: 480.889.0831
For those of you using Mark Fisher, have you been happy with his service? I used him in the past. Initially he was great, but a year or two later I needed to adjust my policy and I could not get any response from him either by phone or email. Just wondering if it was an isolated incident or not.
I have no issues with him.been fine for me.
Thanks to all for the input. I tried contacting Foremost directly. I told them it was a Trooper 1100cc, not a renegade 800 and they said they would call me back. Never heard from them again. Just spoke with Mark at Fisher Insurance, he was great! Got me set up with a policy for $300/yr! Beats the heck out of what my previous insurance agent did for me ($800/yr), and he did it in just 10 min.
  • 2 months later...
    • By Thearm
      I have a 2018 TW450 that runs fine on flat ground but dies out when under load going uphill. Changed the gas filter and spark plug with same results. Letting it set for a few minutes it will run until it hits a incline. Belt is not slipping, but the engine just dies out and doesn't even want to run in neutral. Any ideas as to what I can try is appreciated in advance. Also only run non-ethanol for fuel.
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By Jody Deville
    • By KMP
      We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT.  We are truly beginners and welcome any and all suggestions.  Thank you, we appreciate your help!
