Ok, so it seems to me that if I'm going to have to rebuild the motor anyway, a little Sneaky Pete setup on the 650 might be fun. I'm thinking something to top the dune at Comp Hill, that kind of thing.
Has anyone built a N2O system for a Joyner? I figured I'd drill and tap the bottom of the intake with Fogger nozzles, put the smallest jets available in and hit it halfway up.
Anyone done this?
Anyone done this?
You're crazy. But a good kind of crazy.
I was actually thinking, as I noodled it a bit, of two Fogger nozzles, one in each manifold runner, which would provide both the fuel and the N2O. The issue I can see is the size nozzle required may be much smaller than normally used.
Here's the math: 650 cc in two cylinders is roughly equal to 1300 cc in four cylinders, or 2600 cc in a V8. That's a very small displacement, and many nozzle setups are for 5700 cc or larger V8 models.
The EFi kit, I don't think would work, because the car is a carb setup. Maybe some Joyners are EFI, it would work on that, where you just add the N2O in a nozzle, and have the computer add extra fuel when the N2O is activated.
I really don't need the extra power all the time, just at the tops of dunes, so this could be the hot setup until the motor goes completely and I get the Silver Bullet kit.
Hmmm....
Im sorry i assumed u had a trooper i guess... check out Highlifter.com. they custom build kits for atv's ans side by sides. They will prolly suggest an efi pump for the nos kit but they will run 2 fogger nozles and know the correct jet sizes
A little research showed that the N2O kits with a pair of fogger nozzles and all the parts are more expensive than the Silver Bullet engine kit. And, I'd be adding N2O to an engine with cast pistons.... Maybe Silver Bullet first, then N2O..... In the meantime, I put the evac system partially in place. If I didn't want everything nicely painted, it would probably be easier <_<
So, I've been collecting bits and pieces on eBay for my buggy nitrous system. Kinda fun putting little bits together to see if you can make it work. Crankcase evac really woke it up, by the way.
    • By nrggaragebuilds
    • By Firewalker918
    • By Thearm
      I have a 2018 TW450 that runs fine on flat ground but dies out when under load going uphill. Changed the gas filter and spark plug with same results. Letting it set for a few minutes it will run until it hits a incline. Belt is not slipping, but the engine just dies out and doesn't even want to run in neutral. Any ideas as to what I can try is appreciated in advance. Also only run non-ethanol for fuel.
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
