I realize this part is discontinued but im trying to find this exhaust pipe fir my dads 550. His brother who has since passed bought this mule for my dad who is now 90 and he is trying to fix everything on it. I'm willing to take a used one. A new one would be great if someone still had in stock. I'll take anything as long as it is in workable condition. If anyone has any ideas for me im open to hearing them. Thank you so much.
