2008 joiner renegade t4
By Jeff freeman
By riggy400
Bought a Coleman 400 UTV (pretty much a Hisun), the previous owner tried to replace the timing chain, couldn't time it properly and sold it to me. After some hours I figured out how the timing all is supposed to be set (I think/hope) and as I am reassembling, I noticed that the water pump gear was awfully hard to spin. I held the gear with my hand and spun off the impeller. I checked the bearing, spins great no obvious issues noticed other than this o-ring which seems to be out of place? When I remove this o-ring and reassemble the WP, it seems to spin nice and easy without a drag. I looked up the service manual (although very inaccurate info there often) and don't see this o-ring present. Am I missing something here or what? Any input?
This is not easy to access once the engine is back in the machine so would like to avoid having to deal with this if it becomes a problem.
By jugliner
I have a fuel injected UT400 that will start and idle, but surges and sputters at higher speed. It has been sitting for 2-3 months and was fine when parked in garage. I assumed it was a fuel/air problem and pulled the throttle body and cleaned it up. I've ended up replacing the injector, IAC valve, MAF Temp Pressure Sensor, and fuel filter. I've also checked the spark plug, Still surging. I reset the ECU after every component swap.
I plan to pull the throttle body again and look evrything over for any visible leaks, etc.
Any suggestions would be appreciated on next steps. The problem developing after sitting makes me think it should be something simple, but I'm stumped. BTW the fuel was fresh and treated with Stabil.
Thanks.
By AlphaSerenity
Hello,
By bcorneliusen
Hi,
I have recently inherited a 2017 Mahindra mpact 1000 S Diesel flexhauler. The small silver-bezeled indicator gauge on the dash is no longer working since the wires were accidentally pulled from the back. I have managed to connect the correct wires for the seatbelt safety but most are still unplugged. Any pics or a wiring diagram for that gauge would be helpful.
